308 user(s) are online (255 user(s) are browsing Forums)
MikeO Can't open Hood on 87 Vette
1 Posts
I adjusted the right side adjuster on the hood latch and now the right side will not unlatch. How can I unlatch the rich side. I have tried to pull the right side cable under the dash, but did not work. Thanks for any help.
Posted on: 2007/5/20 16:52
bogus RE:Can't open Hood on 87 Vette
this can be tricky...
try this: if you over adjusted (under? not sure) the latch, it might just be too tight. Have someone sit on that corner of the hood, then pull the release and then lift up. It might just need releaved a bit.
The other option is to make a tool that will hook the cable and pull it.
Another option is to pray....
Posted on: 2007/5/20 17:55
VtVette RE:Can't open Hood on 87 Vette
Las Vegas, NV
357 Posts
I've also had luck having someone pull and hold the hood release lever while you pull up on the opposite side of the hood (left side in your case). This works more often than not. Hopefully is works for you.
Posted on: 2007/9/2 3:42
Brian
VTvette
