200 user(s) are online (177 user(s) are browsing Forums)
shmidtd 91 Misfiring
Pisa, Italy
7 Posts
My 91 has developed a misfire and I believe it is fuel related. I've replaced the Cap, rotor, plugs and megg'd the wires. The injectors were replaced in 2001 with factory new ones but the car mainly sat. What is the name of and where might I get the fuel injection cleaner that connects to the fuel rail and you pull the fuel pump fuse, run the car until it quits and the injectors are clean?
Posted on: 2007/7/13 4:48
PeteK RE:91 Misfiring
Napa should have it. I use the Amsoil PI injector cleaner with excellent results. Every time I dissassemble an engine, I run some PI through the system first . Valves and ports are usually cleaned up nicely.
Posted on: 2007/7/13 12:06
shmidtd RE:91 Misfiring
Pisa, Italy
7 Posts
Thaks PeteK the Napa stuff did the trick!! :thumbright:
Posted on: 2007/7/15 1:37
