733 user(s) are online (282 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
joeb1 Door bumper strip on c4
11 Posts
The strip that runs about halfway up my doors is fading. Has anyone found a good product for shining this up?
Posted on: 2008/6/29 1:32
Matatk Re: Door bumper strip on c4
22996 Posts
There are products you can find at the local murrays, napa, etc. I think one is called Back to Black. I've never used it, but I've heard of good results with it.
Posted on: 2008/6/29 16:26
Flashman Re: Door bumper strip on c4
Tampa Bay, Florida
174 Posts
Hello JoeB1,
I use a product called Aqua Gloss Tire Shine, It works great on C4 plastic trim and rubber moldings, It removes the fading and is water repellant. I also use it on the weather stripping under the targa top and the rest of the car. Also, keep that rear window weatherstrip lubed or the rubber will eventually break down. Down here in Florida, the sun sucks the life out of rubber and plastic trim. Aqua Gloss has great UV protection and can also be used on interiors because it is a water based product. Take care.
Joe-Flash Man
Posted on: 2008/7/29 13:42
