205 user(s) are online (147 user(s) are browsing Forums)
TommyT-Bone, more...
mojo92 Motor running rich
Tifton,Ga.
58 Posts
We just got the motor back in the car after a rebuild and now the motor is running rich. We think that one of the injectors is bad. We took it lose and the tune did not change like it did with the others. #1 injector I thank, would this make the motor run that way ?
Posted on: 2008/8/3 23:29
FATED Re: Motor running lean
Texas
157 Posts
Yes, might run hot too.
Posted on: 2008/8/3 23:34
bogus Re: Motor running lean
20860 Posts
check the fuel filter.
check fuel pressure. Be sure the fuel pressure regulator is doing its job.
be sure there aren't any vacuum leaks.
Posted on: 2008/8/3 23:43
mojo92 Re: Motor running lean
Tifton,Ga.
58 Posts
would it be a good thing to buy a all new injector, fuel rail and fuel pressure system ?
Posted on: 2008/8/3 23:48
20860 Posts
injector. It is SO rare when the rail fails...
FPR is a good idea, especially if the new engine is more than stock.
Specs, please?
Posted on: 2008/8/4 0:08
MK 82 Re: Motor running lean
Palm Beach Gardens, FL
439 Posts
Running rich doesn't make it run hot. Actually the opposite.
Posted on: 2008/8/6 2:30
96 CE Roadster LT4
439 Posts
Posted on: 2008/8/6 2:31
96 CE Roadster LT4
