141 user(s) are online (108 user(s) are browsing Forums)
The Natio...
jsup Miniram Question.....
1778 Posts
Got my Miniram and 58MM TB today. NICE piece. Looks like good quality equipment. They now use a gunmetal gray anodizing for the Throttle Body and the Fuel Rails, looks great.
Anyway, I have FIVE Vacuum fittings on my car:
1. AC Ducts
2. Fuel Pressure Regulator
3. MAP sensor
4. Brake Booster
5. Valve Cover
The Miniram only has FOUR connections.
Three for the smaller fittings. The larger fittings include Brake Booster and Valve Cover Hose.
I am considering having a hole drilled and tap in the back of the MR for the brake booster.
How do you guys do it?
Thanks
Posted on: 2008/8/25 20:33
JonnyAngle Re: Miniram Question.....
Minneapolis, MN
151 Posts
You can tap in one of them from the throttle body if it has the extra port on it. I don't have a MR, but that's what came to my mind.
Posted on: 2008/8/25 21:03
