146 user(s) are online (98 user(s) are browsing Forums)
Sheet Molded Compound.
The onl...
kelley service eng
thomasville ga
122 Posts
got back from a great ride top down and 50 mi in the 94,got back home went to put it away light came on,,service eng light . put scaner on it and got a (63) bank 1 error? what is that?
Posted on: 2008/9/28 20:56
biggrizzly Re: service eng
My quick Datamaster lookup says Right O2 fail, but I'll check another place for you. BRB
You got a bad O2 sensor looks like or your connector is loose or something of that nature. At least it will point you in the right direction.
Posted on: 2008/9/28 21:23
kelley Re: service eng
thomasville ga
122 Posts
thanks thats what i got,the info center on right side of wheel says service asr ,,guess it didn`t like the ride...kind of like an old horse turning BARN SOUR,,,
Posted on: 2008/9/28 22:12
I think the service ASR can mean low brake fluid or air system
Posted on: 2008/9/28 22:14
Schrade Re: service eng
63 which module? mod 1, 4, 9, mod A?
Module 4 DTC 63 is front heated O2 'open' in the circuit.
If this is so, you MIGHT be able to swap the front and rear and test to see if this fixes the problem. There is no DTC indication for right side REAR O2 fault.
I tried this, and it did NOT fix the problem. WHY???
Possibly BOTH of my rt side O2's were bad.
I bought a new one, put the REAR O2 back into the rear fitting, and the new one in front. The problem is fixed.
To solve the puzzle, I would need to drop the cat, and switch the front and rear again, which I might do when I get Mr. grizzly's headers from him, but if it trips up the fault code, that would be a pain to drop and swap AGAIN...
Posted on: 2008/9/29 2:13
thomasville ga
122 Posts
its the traction control..and don`t have a clue.
Posted on: 2008/9/29 16:47
Yep
Posted on: 2008/9/29 17:25
