202 user(s) are online (137 user(s) are browsing Forums)
Assembly Line Diagnostic Link
DUBIE sounds like a pop corn machine
NY
33 Posts
!1991 vert auto 81k ---dog on performance---but when I try to get it to acceleratre and auto down shift it sounds like an out of control pop corn machine from down below. This tranny did eat a race a while back and it was replaced but not flushed out again since.
Posted on: 2007/11/20 21:52
bogus RE:sounds like a pop corn machine
20861 Posts
yuck... whenever something breaks like that inside a transmission, I worry about clutch faces...
I would power flush, change the filter and see what happens.
Posted on: 2007/11/21 0:55
DUBIE pop corn
NY
33 Posts
That's exactly what I was thinking---worth a shot I guess thanks
Posted on: 2007/11/21 1:37
CasetheCorvetteman RE:sounds like a pop corn machine
First thing id be doing is getting the fluid and filter out of it, THEN id be opening that filter up to see what you have inside. From that, youll be better able to make a judgement.
Posted on: 2007/11/21 3:40
DUBIE popcorn
NY
33 Posts
Well, had the full flush done at jiffy---smells better--fluid that is. Initially, more popcorn sounds than before will continue to evaluate and see if anything improves---any chance of the rattle noise being an exhaust tube from the air pump or something like that???
Posted on: 2007/11/22 0:06
Did you personally inspect the inside of the filter? That is the most important thing you shouldve done.
Posted on: 2007/11/22 6:32
DUBIE popcorn
NY
33 Posts
Didn't check filter because Jiffy back flushed without touching anything. Since initial drive---car is running better and less popcorn noise at lower RPMs. There is no doubt that there was residual metal from previous problem in the fluid. Hopefully there is less now.
Posted on: 2007/11/26 15:34
