166 user(s) are online (118 user(s) are browsing Forums)
BrianCunningham Online Aerodynamics Model
neat stuff
http://forums.corvetteforum.com/c4-te ... model.html#post1568960321
[QUOTE]SuperL98;
I stumbled across an interesting Free Online flow simulator called “Flow Illustrator”
You can upload your own Bitmap images into it, so I figured I would try out a C4
Don’t know how accurate it is but fun anyway
See if I can get everything to post, got a little blurry eyed playing with this all day
The Bitmaps I made from a C4 technical drawing
[IMG]http://i237.photobucket.com/albums/ff47/SuperL98new/master640solid.jpg[/IMG]
[IMG]http://i237.photobucket.com/albums/ff47/SuperL98new/master640rad.jpg[/IMG]
And the Youtube videos, quality isn’t to good, unfortunately
Stock C4
http://www.youtube.com/watch?v=CPzo40SqO4E
C4 With a rear wing
http://www.youtube.com/watch?v=s_Rxn1Nc1dg
My C4 with a Greenwood Body Kit
[IMG]http://i237.photobucket.com/albums/ff47/SuperL98new/SuperL98.jpg[/IMG]
http://www.youtube.com/watch?v=SRKqlwfylyk
& With radiator open
http://www.youtube.com/watch?v=oW8X5d5xllM
The home page for Flow Illustrator is
http://chernyshenko.sesnet.soton.ac.uk/FlowIllustrator.aspx
You can modify & use my (24 bit) Bitmaps above
Click on bitmap and upload your image
2 :1 ratio images are best 640 by 320 , 512 by 256, etc
Re = Reynolds’s number = I used numbers in the 2,500,000 to 6,000,00 range
Dt = leave this alone, has to do with quality
Sec = video time – Anything over 40 sec takes forever.
Have fun!!![/QUOTE]
Posted on: 2009/2/16 0:14
bogus Re: Online Aerodynamics Model
20860 Posts
very interesting.
I wonder what a rear diffuser would do?
Posted on: 2009/2/16 0:19
