227 user(s) are online (154 user(s) are browsing Forums)
Driver Information Center.
CorvetteMike ECM ground?
4 Posts
I know my ECM ground is suposed to be on the back of my engine block on drivers side. 89 vert. I cant find it looking down in that tight spot. Any suggestions on how to find it? Been looking from top. Should I be looking from bottom? Thanks for any advice.
Posted on: 2007/10/4 3:13
CasetheCorvetteman RE:ECM ground?
You might find it abit easier from looking up underneath.
Posted on: 2007/10/4 3:37
JAKE266 RE:ECM ground?
Kempner, Texas
22 Posts
Right. From memory, it's forward of and slightly above the oil filter housing. There should be several wires grounded to the block by a single bolt. I can't remember specifically, but the head of the bolt is pretty large, something like 11/16" or 3/4".
Also there is another single ground wire that runs to the frame in the same area.
Jake
Posted on: 2007/11/3 19:43
bogus RE:ECM ground?
you are thinking on two different places, combined into one!
The multi-wire grounding point is on the block/transmission juncture. It's one of the bolts that holds the transmission to the engine.
The other bolt is the ground strap, but it's a solo wire. And yes, it's real big.
Posted on: 2007/11/3 19:47
ITHZ RE:ECM ground?
Carrollton,Ga
46 Posts
Not to hijake,but would this be the same on an'87?
Posted on: 2007/11/4 5:00
AFAIK, it's the same on all year C4s.
Posted on: 2007/11/4 7:55
pappyfreebird RE:ECM ground?
1028 Posts
newbbe here n i kin say i preciate you cats awready ...thanks pappy
Posted on: 2007/12/26 22:34
