169 user(s) are online (119 user(s) are browsing Forums)
NorCal86 Which flywheel for an 86 iron head?
Sacramento
3 Posts
The listings I find show up to 85 then 86-88. But, are they talking about the change made during 86 and does my early 86 need the same as the 85 or the 86-88?
Posted on: 2007/12/30 3:13
CentralCoaster RE:Which flywheel for an 86 iron head?
They are different:
84-85
86-88
You want the 86-88. Should be a 153 tooth for a 1-pc rear main seal.
Posted on: 2007/12/30 3:25
