162 user(s) are online (118 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
Oaklands Shifter knob acting up
Morristown, TN
480 Posts
I am having a little trouble turning OD on and off with my shifter. Could it just be a little bent under the top off the shifter knob? I am guessing all I need to do is take a screwdriver and pop the push down part (diagram of the shift sequence) with a screwdriver and see if everything looks ok?
This is on an 88 4+3.
When it works, the shifting between OD and out is fine.
Thanks,
Keith
Posted on: 2007/12/31 4:47
