205 user(s) are online (127 user(s) are browsing Forums)
These are commo...
josephf31 Oil temp guage not working
New Jersey
375 Posts
On my second cluster now, still doesn't work; is it most likely the sending unit gone bad? or could there be something else? Thanks!
Posted on: 2009/8/3 0:31
Durango_Boy Re: Oil temp guage not working
The sending unit is very expensive, so try a simple test first.
Pull the wire off of the sender and touch it to bare ground with the IGN on. Does it stay at zero or does it peg?
If you get no change at all, and this is your second cluster, then it is most likely your sender or the wiring from the sender.
The computer 'might' be involved with the interpretation of the sender reading so maybe a C4 guy knows more about it. If it's direct, there are only three things to look at. The sender, the wiring, or the gauge itself.
Posted on: 2009/8/3 2:30
bogus Re: Oil temp guage not working
your getting nothing? that's odd. Check the wiring. The connection down there is prone to heat related damage. The temp sender is down above the oil filter housing, on the block.
BTW, the sender isn't very expensive for the C4 and the computer does nothing. This is a direct signal to the IP.
Posted on: 2009/8/3 6:01
I bought an '82 oil temp gauge sender for my '77, and it was close to $45. As far as senders go, that's horribly expensive. LOL. What do they cost for C4s?
Posted on: 2009/8/3 9:36
gee... I don't remember, but NAPA online should have a price. Also check Rockauto.com.
Posted on: 2009/8/3 10:17
josephf31 Re: Oil temp guage not working
New Jersey
375 Posts
At rockauto it's about $35 plus shipping
Posted on: 2009/8/4 1:51
I would still check the wiring and try to test the circuit.
Two IPs tell me that unless you are jinxed, the sensor or the wiring is at fault.
Posted on: 2009/8/4 7:10
rogerwillson Re: Oil temp guage not working
8 Posts
Take it to garage.
Posted on: 2009/8/4 11:24
Mind Games
New Jersey
375 Posts
rogerwillson wrote:
Take it to garage.
You're quite the comedian...
Posted on: 2009/8/4 17:15
Yea, I was overwhelmed by that helpful advise...
Posted on: 2009/8/4 22:12
New Jersey
375 Posts
Well, after a nice long ride on the highway tonight, the oil temp gauge (slowly) moved up to about halfway point, which appears to be normal operating temperature. It seems that idling while not moving, even for extended periods, won't move the oil temp guage!
On the same ride my left front speaker started working again, which had quit recently. I'm on a roll!
Thanks all for your help...
Posted on: 2009/8/5 2:10
whoo-hoo!
A weak sensor will cause a slow read, tho...
Posted on: 2009/8/6 13:01
