Browsing this Thread:
2 Anonymous Users
Register To Post |
jsup | Re: Low coolant temps and no heat | ||
Maybe it's clogged....hmmm... How does a constant flow work in the summer? How do they keep the heat down. |
Posted on: 2008/11/27 22:01
Parts don't make power, engines make power. |
Transfer |
BillH | Re: Low coolant temps and no heat | ||
The Stig Moderator
They don't! The path to the heated core is shut off by the temperature mix door but it's still there with hot water in it. Even when you first turn on the vent, it's hot. I always hit the A/C for a minute before going back to vent in the summer. On hot days, the vent isn't enough. Hell, I run the A/C with the windows down just to cool my feet sometimes. |
Posted on: 2008/11/27 22:24
Every man dies but not every man lives. |
Transfer |
Schrade | Re: Low coolant temps and no heat | ||
If I have to drain good coolant, it goes into a scoured-out bucket, and still gets filtered through a coffee filter before goin' back in.
No reason to toss good juice... |
Posted on: 2008/11/28 4:28
LT5, Marc Haibeck ECM module, AUTOMATIC!!! |
Transfer |
Ya know, having the HC in constant flow probably also helps with engine cooling a bit too.
Posted on: 2008/11/28 13:47
Transfer |
Yup. And if you got Sux-cool in your lines, keep it turned on high as much as tolerable. |
Posted on: 2008/11/28 14:38
Transfer |
