180 user(s) are online (102 user(s) are browsing Forums)
jsncable Brake Pipe
Jacksonville, FL
10 Posts
Quick question! Anyone know the original brake pipe and fuel pipe diameters for the 1984 C4? Mine have to be replaced the brakes sat with water in them for a Looong time.
Posted on: 2011/1/28 19:40
Raidmagic Re: Brake Pipe
Florida
168 Posts
I've got a parts car at home I can get some measurments from it for you later.
Posted on: 2011/1/28 20:19
jsncable Re: Brake Pipe
Jacksonville, FL
10 Posts
I can measure them when I get home, I was just wondering if someone knew off the top..
bogus Re: Brake Pipe
I THINK the fuel line is 3/8" ID, and the brakes are 1/4" ID.
That sounds about right...
Posted on: 2011/1/29 2:00
RestoMod57 Re: Brake Pipe
Phoenix, AZ
55 Posts
88-96 C4s have 3/16" double-walled brake lines. Not sure about the early C4s.
Posted on: 2011/1/29 16:21
Jacksonville, FL
10 Posts
Thanks, I'll look into it.. I have the service manual now, and you'd think it would be in there somewhere.. but I havn't found it yet.. lots of stuff to look through..
Posted on: 2011/1/29 16:50
it won't... you will have to hit the hoses in question with a caliper and measure.
Posted on: 2011/1/29 18:37
