62panshovel | Targa Top repair | ||
My solid SMC not plexi top is starting to release from the frame. What do the Guru's suggest as the best/most appropriate adhesive to bond the SMC back to the frame? I only wish to seal it back where it is beginning to release and not remove it and start from scratch if at all possible...
Posted on: 2011/6/17 17:54
BillH | Re: Targa Top repair | ||
You need panel bonding adhesive. Be aware, it's pricy.
Click on the "restoration shop" here on the left then, search 3m panel bonding adhesive. Also here: http://www.tcpglobal.com/autobodydepo ... sives-sealants-foams.aspx And look at 3m 8227 repair adhesive, it's $35 vs $45 for some of the others. And a lot of these need an outomix gun to push the stuff out of 2 tubes but you can rig a way to do it at home. Use a lot of tape, cover everything the this stuff could get on. There's also 3m Structual Adhesive @ $19.00 I have some and used it to repair the fibrrglass heater ductwork on my C2. But it's white in color and remains slightly flexable. |
Posted on: 2011/6/17 19:08
j3studio | Re: Targa Top repair | ||
Interesting ...
... I've never heard of this happening with the solid top, but I guess there's a time for everything. My plexiglass top needed the same kind of help at about 21 years: bugs were flying in the front and splattering against the inside of the rear sail panel. |
Posted on: 2011/6/18 12:46
