damien89 | A big piece of foam inside the door pillar vent, is it from factory? | ||
I removed the triangular vents which are located in the pillar where the doors close, where the foam that i found put their from the factory?
If yes what is their purpose? |
Posted on: 2011/10/2 15:06
j3studio | Re: A big piece of foam inside the door pillar vent, is it from factory? | ||
Picture, please.
Also, I'm assuming that you have a 1989 - is that correct? |
Posted on: 2011/10/2 18:01
damien89 | Re: A big piece of foam inside the door pillar vent, is it from factory? | ||
Yeah sorry forgot to mention that, 89 coupe Will try and take one toomorow. |
Posted on: 2011/10/2 18:10
bogus | Re: A big piece of foam inside the door pillar vent, is it from factory? | ||
It might be... GM used lots of foam to quell squeaks and rattles... and the foam slips...
Posted on: 2011/10/2 19:18
flyboy | Re: A big piece of foam inside the door pillar vent, is it from factory? | ||
I believe that vent and the ones in the rear speaker housing are a system to give air pressure release when hatch/doors are slammed shut with windows up. Mine has a piece of foam also; think it's to keep dirt from infiltrating the cabin.
Posted on: 2011/10/3 1:07
