postalvette | power steering pump replacement 84 vette | ||
Anybody have the steps to take from the maintenance manual for power steering pump replacement?
Posted on: 2011/11/1 12:35
bogus | Re: power steering pump replacement 84 vette | ||
I doubt it's all that bad... you will need a pulley puller, tho. Crowsfoot socket to remove the lines...
Posted on: 2011/11/1 15:54
postalvette | Re: power steering pump replacement 84 vette | ||
Do you have to remove the smog pump, resevoir, and alternator to get it off or are there some shortcuts? I read that you have to have a special tool to get the pulley off, any truth to that? Also does the pulley have to come off first to get to the mounting hardware for the power steering pump? Guess I'll just jump in and find out. Thanks for the input.
Posted on: 2011/11/1 23:18
the special tool to get the pulley off is the pulley puller. you can get them all day long at Autozone or what not for about $20.00.
See the attached screen shots. |
Posted on: 2011/11/1 23:33
BillH | Re: power steering pump replacement 84 vette | ||
You can rent/borrow a p/s pulley puller/installer at a lot of auto parts stores.
You can also buy one for around $24.00 |
Posted on: 2011/11/1 23:35
