BrianCunningham | How do you hide your IP address? | ||
I figured maybe that would slow down this spyware stuff.
My anti-spyware keeps going into overdrive. |
Posted on: 2008/1/5 22:41
C4DERF | RE:How do you hide your IP address? | ||
Once your "packet' leaves your Local Area Network (LAN) there are several layers of protocol headers that contain ADDRESS information assigned to your computer.. If you run a private network ie: a wireless router in your home the router will clone the computer's MAC address (the interface connection to your LAN) and provide you a private IP address within your home network and use the IP address your Internet Service Provider (aka ISP) like comcast, roadrunner, charter, etc as it's own IP. Sometimes you can run something called NAT/PAT which is a Network Address Translation to Port Address Translation but most ISPs don't like it so much. Conntact your ISP and see if they run any type of pre-filtering for SPAM and Virus detection before they send it down your LAN connection. Generally this will slow down your bandwidth on your LAN. Hope this helps a bit.
Posted on: 2008/1/5 22:53
94 C4 LT1 A4 Polo Green w/Lt Beige Coupe Can I join the 600 club???? I can only round up 598 at present! :book: [IMG]http://i151.photobucket.com/albums/s150/c4derf/CasualCorvettes-SonicAug07011.jpg[/IMG] |
Jeffvette | Re: How do you hide your IP address? | ||
[quote]I figured maybe that would slow down this spyware stuff.
My anti-spyware keeps going into overdrive. :banghead] I like the idiots reply to your post in CFOT. Well both of them. |
Posted on: 2008/1/6 0:37
BrianCunningham | RE:How do you hide your IP address? | ||
You noticed that too.
Really, I'm still on there. I just want to get my computer to run faster. |
Posted on: 2008/1/6 1:00
