ironcurtain | Passenger Side Door won't open | ||
Hey guys. Little issues keep coming up with my car and well I thought I would ask about this one.
My passenger side door won't open from the inside. I have to open it from the outside. I'm planning on looking much more into it tomorrow since its my day off and just thought I would ask you guys and see if I could be steered to the right direction. THanks!! |
Posted on: 2008/1/6 6:10
RRTvette | RE:Passenger Side Door won't open | ||
Your going to have to take the door panel off and investigate.
Posted on: 2008/1/6 9:32
94z07 | RE:Passenger Side Door won't open | ||
Odds are that the door handle rod has come out of its anti-noise plastic clip. This clip keeps it in line with the accessory panel and keeps it from making a rattle while driving. The clips can be found in the HELP! isle at AdvanceAuto Parts. The clip has likely broken or become brittle enough to let the rod slide out. The good news is that the clips are cheap. As in 4 for $2.50ish. The bad news is that it is a real pita if you have to take that accessory panel out. I would sacrifice the cuts and scrapes on my hands to avoid taking that panel out if I could reach the spot via the holes.
Posted on: 2008/1/6 17:48
