204 user(s) are online (143 user(s) are browsing Forums)
The Natio...
sliding New alternator
Zagreb, Croatia
326 Posts
I hope that I have finally solved my problems with alternator.
I have rebuilt my stock unit x times but it just kept failing.
I guess that stock alt doesn't like high revs, because it allways broke
when I reved engine past 6k rpm.
Anyway, I bought CS-144 140 Amp alternator. I did some search and
it looks like everybody agree that it's much better unit than stock CS-130.
Maybe I could've played with larger alt pulley but I hope that this will be
longer lasting solution.
Posted on: 2008/1/8 18:44
biggrizzly RE:New alternator
Did it come with the pigtail I see in the photo? I cracked my connector and I wondered if I bought a new alternator if it would come with the connector?
How much did it set you back?
Posted on: 2008/1/8 18:59
sliding RE:New alternator
Zagreb, Croatia
326 Posts
Alternator was $170. I bought pigtail separately for $10.
This is where I got it from:
http://www.alternatorparts.com/CS-144_Special_offer.htm
Posted on: 2008/1/9 18:30
