Frank | 1984 Dash | ||
Ugg! My dash was blinking on and off (again) so in my infinite wisdom I started tapping on it. Yep, you guessed it, I tapped too hard and the glass(?) cracked and the dash is still blinking. I believe its even taunting me. So here's my question(s): How hard is this job? Has anyone successfully upgraded their dash? Thanks in advance for your help.
Posted on: 2012/9/13 21:02
bogus | Re: 1984 Dash | ||
it's not hard... just expensive.
I have more info at home, I will update then. |
Posted on: 2012/9/13 21:22
this is one option...
http://vettaid.com/ReplacementGauges/C4GaugePackages.aspx however, flickering lights make me think something is amiss in there... http://www.batee.com/corvette/dcrg/re ... oard_connector/repair.htm that link should give you an idea how to work on the IP. |
Posted on: 2012/9/14 2:22
Matatk | Re: 1984 Dash | ||
The glass panel can be replaced. They can be found on ebay. The flickering is most likely caused by a bad ground.
Posted on: 2012/9/14 2:59
