268 user(s) are online (235 user(s) are browsing Forums)
The Natio...
jacobsimmons ses
lititz pa.
40 Posts
my ses light came on this morning on my to work, i was on the high way at 65 mph and there it was, when i got off and at my first stop light i thought the idle
was a bit rough. when i got to work i remembered the car manual saying for a rough idle try taking the rpm up to 2k for 2 mins. and thats what i did, then when i restarted the vette the light was off and did not come back on during the drive home. being a new owner i'm just thinking is this an oxygen sensor going bad or what. any help would most appreciated . thanx.
Posted on: 2012/10/25 20:15
1Fast04Vert Re: ses
The best way to find out is to get a paperclip and then see what codes it has set. There should be an "H" (history) code set.
Posted on: 2012/10/25 20:52
pianoguy Re: ses
Here's some info on how to retrieve the codes with a paper clip:
http://www.digitalcorvettes.com/forum ... .php?p=240218&postcount=2
Posted on: 2012/10/25 21:15
jacobsimmons Re: ses
lititz pa.
40 Posts
thanx for the info.
Posted on: 2012/10/25 21:26
j. simmons
bogus Re: ses
Moved to C4 Tech!
Posted on: 2012/10/25 22:19
bogus Re: ses
I must suggest... before you get much deeper in this car, get a Helm Factory Service Manual.
http://www.ebay.com/itm/1993-CHEVROLE ... sh=item35c0e1a71a&vxp=mtr
or
http://www.ebay.com/itm/1993-CHEVROLE ... sh=item51a2e8cd5b&vxp=mtr
You need the 2 volume set, NOT the LT5 supplement, and not the white covers, they are prelim versions.
Posted on: 2012/10/26 3:03
lititz pa.
40 Posts
thanx for the info. i was trying to figure out the manual to get, that sounds good.
Posted on: 2012/10/26 12:43
j. simmons
