bam | stock timing and VE tables | ||
Could someone post the stock timing and VE tables for the 93 Vett? I have somehow lost mine in all the tuning I have been trying to do on my 93, sure would appreciate it.
Posted on: 2012/11/16 15:21
bogus | Re: stock timing and VE tables | ||
isn't that data available via TunerCat? I should have it if that's the case...
Posted on: 2012/11/16 18:49
bam | Re: stock timing and VE tables | ||
Bogus, yes you can read your stock tables with TunerCat. If you have the ECM file on your laptop/desktop computer already you can just load it in TunerCat and then do a screen print of the appropriate tables. If not on your computer then you will have to have the Moats flash and burn program and a chip burner/reader to read the chip. Thanks
Posted on: 2012/11/16 19:48
You could also just sent the whole stock ECM bin file, whatever works best for you. I finally have my idle and part throttle VE's working pretty good, but now I am very rich at WOT, around 10.0 AFR reading on my wide band 02.
Posted on: 2012/11/17 0:34
Woodstock | Re: stock timing and VE tables | ||
Posted on: 2012/11/17 1:15
91 convertible |
