CorvetteBob | Bottle jack for QuikLift? | ||
Last year I got a deal on a used quik-lift. It has the centerlift bridge you can use to place a jack under the car and lift it for pulling the front wheels off. The old Q-L site showed a bottle jack in use. I've been looking at bottle jacks to find one, but I'm not finding one that seems adequate. I have about 10" from the bridge to the front crossmember, so that's not too bad, but I'm not sure how much of a stroke the jack needs to have. They all seem to advertise minimum/maximum range, but that includes the screw on the top going from all the way down, to all the way up with the top screw completely extended. So what do I need as far as actual extension of the jack, not including the top screw?
Also, due to the shape of the front crossmember, do I even want to use a bottle jack, or should I try another approach? Thanks in advance for helping. |
Posted on: 2013/3/2 6:56
bogus | Re: Bottle jack for QuikLift? | ||
I use an AC Hydraulic... sad, they are no longer available here in the states...
http://www.ac-hydraulic.dk/en/products/hydraulic-jacks/dk13hlq/ with that said, have you checked Harbor Freight? Picking up via the crossmember is fine... but it will bend it some over time. But so will tall speed bumps. |
Posted on: 2013/3/2 7:27
CorvetteBob | Re: Bottle jack for QuikLift? | ||
I've been looking at harbor freight alot. They're just about the worst offender for giving minimum/maximum only without actual range of jack movement. As for the bending of the crossmember, I'm working on a type of plate to support the whole width of the crossmember so the weight isn't on just one small area. BUT, I need to know what kind of lifting device I'm gonna end up with first.
Posted on: 2013/3/2 7:44
BillH | Re: Bottle jack for QuikLift? | ||
Here Bob. just an example, shows ram stroke, screw range,etc.
http://www.northerntool.com/shop/tools/product_200304831_200304831 Or, northerntool, auto repair, bottle jacks for all of them The also have an air operated one @ $59.00 Also, don't know tha dimensions of the tray you are going to set this in but bottle jacks can be a tad shakey. I'd give some thought to tack welding the corners of the jack base to a larger piece of 1/4 plate. |
Posted on: 2013/3/2 13:41
That jack is available at a local PepBpoys. I looked at it today, but I'm still not sure about what to get. How far does a C4 need to come up b4 the tires leave the surface? |
Posted on: 2013/3/2 21:50
not far... 4" or 5" or so?
Posted on: 2013/3/3 1:11
Thanks Andy, that's good info. I don't lift mine up too much. B4 the QL I used my ramps for oil changes etc... When I was at Pepboys I saw they had a scissor jack that was hydraulically operated. It has good range, and the hyd part makes it easier to use than a ratchet on a lift screw. I guess now is when I face the hardest part of the whole thing, actually choosing and making a decision. I don't know about you guys, but that's the worst part for me. Not just the decision, but because I've made wrong choices before that I couldn't return, so then I was stuck with a non-working solution and had to save up the money to try something else. |
Posted on: 2013/3/3 17:43
