istter1 | 87 corvette Performance chip | ||
Well some of my drag race buddies were over we checked everything several times. The group answer was that I need to up grade to a Performance chip with the 383 stroker. They say that the upgrade engine isn't getting what it needs from the stock chip.
Mat my friends from Famosa coppied the information from those links you gave me. They say the best simple examples of trouble shooting for a beginner or refresher for the pro. Thanks I have never burned a chip and I am lacking knowledge to do so. It was suggested I purchase A performance chip stage 1 . Worth it or not guys advice.Please Steve |
Posted on: 2013/9/24 2:25
Matatk | Re: 87 corvette Performance chip | ||
Regarding the chip, contact PCM4less and have them do a custom one. Around $200 but they will customize it for your mods. Do not get an off the shelf performance chip, or a "stage 1/2/3/4" whatever chip that some companies sell.
I thought you already had a chip in there, I didn't realize you were running a stock prom! Do you have a datalogging cable and software, etc? |
Posted on: 2013/9/24 2:46
istter1 | Re: 87 corvette Performance chip | ||
No stock
"I thought you already had a chip in there, I didn't realize you were running a stock prom!" Do you have a datalogging cable and software, etc? " No That why I ask a lot of questions. Some times I ask the right ones. My buddies thought it was a no brainer to them Thanks Mat will check out PCM4less. Sales Tax: $14.45 Total: $228.45 http://www.pcmofnc.com/index.php?opti ... egory&path=213&Itemid=106 Steve |
Posted on: 2013/9/24 2:56
Steve - you also need to get a datalogging cable to hook up to your laptop. That's about $60. I got mine from moates.net, or you can use aldlcable.com. You can download free tuning software such as datamaster tts or tunerpro. This way you can run scans of the car and email them to the tuner who will make fine adjustments and send you a new file or chip with the enhancements.
You will probably also need a zif adapter for the chip to plug it into your ecm, check with the tuner to see what he recommends. Mine is also from moates.net. |
Posted on: 2013/9/24 11:38
Cool my learning curve is about to grow
Thanks MATTHEW Steve |
Posted on: 2013/9/24 13:20
bogus | Re: 87 corvette Performance chip | ||
What Matt said, 100%.
The upside is that so many of these motors have been built up and the number of variances are limited, so PCMForLess can provide a chip for most every application needed. |
Posted on: 2013/9/24 18:39
I called and talked to them this morning. Getting my build sheet and other info. When we talk next time I will be prepared
Thanks Guys Steve |
Posted on: 2013/9/24 19:59
Mat first step friend gave me a lap top i upgraded it to window7 the tuning software will work with 7? |
Posted on: 2013/9/26 3:06
Posted on: 2013/9/26 4:13
I don't know of any specific problems working with win 7. As long as the comm port recognizes the cable, otherwise you have to download a free program to make the usb port pretend to be a comm port so the computer and cable with play nice. I have that info in an email somewhere I can dig out if you can't get it to work.
Posted on: 2013/9/26 11:33
I am going to order a cable in a few days
Thanks for the info |
Posted on: 2013/9/26 13:19
CentralCoaster | Re: 87 corvette Performance chip | ||
If you are trying to convert usb ports to serial COM ports, then I know there is a lot of adapters that don't work even if they claim to.
One that I have used with success on many computers is made by Keyspan. I was really impressed with the products Moates.net has, particularly the ostrich that lets you flip between programs on the fly, but I never pulled the trigger. It essentially converts your hard chipped ECM prom into a flash/programmable unit. He sells all the cables you need to. |
Posted on: 2013/9/27 4:29
thanks Kevin.I looked at that one on that site. limited knowledge on my part
Posted on: 2013/9/27 4:55
it's a steep learning curve, Steve... you will learn a lot, and feel ok with what you have, but when you talk to real engine tuners, you will still feel like an idiot.
These people are insanely knowledgeable about this stuff... and the entire concept is rather abstract. Don't feel bad if you have issue grasping this stuff. It's not easy and does take years of exposure to get into a good comfort zone. It has taken me a long time to get where I am with this stuff, and I know I am not even close to being "expert". I am in that grey area of "dangerous!" That's why I don't offer much input on these threads. I let the pro's handle it... |
Posted on: 2013/9/27 18:15
You sre echoing the words of my racing friends. Told me me the first time I flash and wipe everything out I will freek Sounds like the old days of mixiing nitro at the drag strip I wonder if there is an idiots data loging book out there |
Posted on: 2013/9/27 23:02
Moates.net
Just ordered cable. They won't be open till Monday Work on chip this weekend Hope to have time Steve |
Posted on: 2013/9/28 0:23
There is no "step by step" guide that I know of, Steve. When I started it was all trial and error. And now when I have to go back and do it again, I have forgotten everything I did to set it up so it's back to step one....lol.
Posted on: 2013/9/28 11:44
Right in my learning curve then.. Looks like chance for someone to make a few bucks macking a basic guide. Not me This forum has a good section that explains and some how to's on data loging. short example of help from this forum TunerPro RT Setting up the Driver 1.Download the driver and Install it. 2.After you install the drivers you will see two COM ports (in Device Manager). One port will be the Consult Port (USB Serial Converter A) while the other one is for the Emulator to upload Tunes (USB Serial Converter B). You will be using the Converter A Port for Nissan Data Scan or any other Consult software. Actual tune modification will be done using Converter B. It's a good idea to make sure the COM ports are as low as possible (under 10). This will help with compatibility with some ancient tuning software that doesn't like higher numbered COM ports. Find the BIN for your specific ECU!!! Nissan updated the tune and the firmware behind it with just about every year they released the car. This means you need to first find the stock base tune that was build for your specific ECU. Loading the bin from another ECU might work, but I've seen some serious issues too. Steps for how to do that can be found here. Loading Tune 1.Download and Install TunerPro RT. 2.Start up TunerPro RT, which should automatically detect your ECU. 3.Open up TunerPro RT, wait for it to load and nag screen go away. You can purchase the software to help you safe some time. 4.If you want to change the default settings of the program, you can do so at Tools, Preferences under the General Tab. I wouldn't worry about this one until later though. 5.First thing we want to do is open an Address file. Click on XDF, Select XDF.... Navigate and select the XDF that you would like to use. 6.Next step is to find a tune (ROM) that you want to modify. Click on File, Open Bin.... Navigate and select the BIN that you would like to tune. 7.Now we can start looking at items that we can tune. Uploading the Bin Uploading the tune is very simple: 1.In the toolbar look for an UP Arrow, should say "Upload Current Bin to Emulator" CAUTION! Your Calum RealTime ecu allows you tune on while the car is running! There are some restrictions to this though, you can only upload changes to the BIN that is currently on the ECU. If you want to switch to a different BIN file, you must shut off the car first, by moving the key to OFF position. 2.Another way to do this is by going to Tools -> Emulation -> Upload Current Bin to Emulator Downloading the Bin From ECU Sometimes you might want to use the Bin that's currently on your ECU. Downloading the bin is as simple as uploading it. 1.In the toolbar look for an Down Arrow, should say "Download Bin from Emulator to TunerPro" 2.Another way to do this is by going to Tools -> Emulation -> Download Bin from Emulator to TunerPro 3.The bin will be now loaded into TunerPro, you can save it, or modify it and re-upload it http://www.sr20-forum.com/ecm-tuning/ ... e-chipped-ecu-tuning.html |
Posted on: 2013/9/28 15:45
Edited by istter1 on 2013/9/28 16:25:30 |
vin 1G1YY2184H5114201
Too tired to get into computer and look up Prom #. Called dealer and got call back monday we don't know what you are talking about on Saturday. Supperised you can't find this information on line . Lots of other questions to answer when getting a chip |
Posted on: 2013/9/28 20:24
Got off my lazy butt and took computer out.
only numbers on chip i hope 8647 is correct. This is the right spot to look at guys?? |
Posted on: 2013/9/29 18:40
Take the blue cover off and the number is on the chip.
http://www.iroczone.com/2009/10/ecmme ... bers-and-cross-reference/ http://www.google.com/url?sa=t&source ... R9Iy0S1dZWPqFd2HEKWSZuVyQ |
Posted on: 2013/9/29 22:38
Posted on: 2013/9/29 22:42
Duh like this in the center of the hole Duh
Picture of Prom code on chip 87 corvette Some days I really feel stupid. I looked at thise site yesterday after a bottle of whine http://www.iroczone.com/2009/10/ecmme ... bers-and-cross-reference/ Thanks Mat ABTC |
Posted on: 2013/9/29 23:54
No problem. Cross reference online looks like that is for your car....y body 87 350 manual trans.
Posted on: 2013/9/30 0:25
Well if I keep asking all the beginner questions we will have to get someone to start a. Basic section about ecm prom and beginng data loading.
Son just got a job with , www.gotshocker.com he is learning with me on data logging and proms.. Need exotic or lift kits contact shocker tell them AJ sent you. He is updating their site adding ideas for stuff he has learned from you guys here. |
Posted on: 2013/9/30 1:08
hm... sounds like he works for the enemy... I work for 4WheelParts...
Posted on: 2013/9/30 1:43
Thought you were retired enjoy the sunny beachs where you live. Sons place is small 1 shop person and they play with their monster truck. |
Posted on: 2013/9/30 3:26
I wish I was retired...
From my best guess, I am 6 magical numbers away. So close, yet so damned far. |
Posted on: 2013/9/30 4:43
Well ordered chip last night.
I had lost some informatiom about the build about the rockers. I was very happy to find out that Summit Racing keeps a record of purchases and the item purchased. |
Posted on: 2013/9/30 13:14
Looking forward to hearing about the results. I think I am going to have Alvin do a chip for me in the spring.
Posted on: 2013/9/30 15:18
Mat orded chip late last night
It is in UPS this morning Some good turn around |
Posted on: 2013/9/30 23:16
Moates has my cable in the Males |
Posted on: 2013/10/1 3:02
kinky.
Chip arrive yet? |
Posted on: 2013/10/2 1:51
Chip will be here Monday. Ups
Cable tomorrow Question I believe I should log information before chip is changed Compare after new chip is installed Do I data log with vehicle parked or driving |
Posted on: 2013/10/2 2:18
You can log before and after and save the files. You should do it driving, the tuner should have given you instructions: ie, baseline idle, pull from idle to 3000 rpm, etc. Ask the tuner.
Posted on: 2013/10/2 15:24
The info will be with he chip. It was a pleasure talking with them. Thanks for recomending them
Mathew |
Posted on: 2013/10/2 20:11
Well cable is here from Moates. It is the xtreme ALDL.
Son coming over later and we are going out to.play with it. |
Posted on: 2013/10/3 1:11
Ok first question. Will I have to solder the chip to my other chip?
Used Datamaster for my first try at logging. Screwed that up. I think I was in a section that my computer didn't recognize. No biggie Finally opened the 383 up lol this baby flies and I didn't make it to fifth 110 little over 3000 cool. |
Posted on: 2013/10/5 21:04
joeld | Re: 87 corvette Performance chip | ||
I'm late to this thread, but here's some info that might help. Read thru this info on installing your new chip. Some folks do solder the new chip in, I don't suggest doing it. This adaptor works fine, I've been running my 89 with this set-up for 2-3years with no problems. Lots of folks here doing the same.
Joel http://www.moates.net/documentation.php?documentation_id=9 |
Posted on: 2013/10/6 3:11
1989 Coupe,L98 automatic |
Rom them Quote:
I looked at that when I ordered my cable Looks simple Been busy trying to import the bin file on ecm to tune pro so I can load the right file for my vet ABTC that has my vehicle 87 y body |
Posted on: 2013/10/6 7:15
I also run the chip adapter and suggest that.
Posted on: 2013/10/6 8:42
Brain dead Mat I am ordering adapter today Been driving my self nuts trying to get. Tune pro to import my bin for my vet |
Posted on: 2013/10/6 15:17
The PCM chip has it's own adapter.
Attach file: pcm2.jpeg (257.82 KB) pcm3.jpeg (260.05 KB) pcm chip install adapter.pdf Size: 525.76 KB; Hits: 135 |
Posted on: 2013/10/8 1:53
If the adapter is included then you are in business. Pop it in and rock n roll!
Posted on: 2013/10/8 2:17
It killing me trying to data log before I put the chip in.
I thought I had everything ready. Toop.my laptop out to car and I had to go to safemode to get it to allow me to log in. Pain.in.butt |
Posted on: 2013/10/10 13:33
The piggy back chip is cool just plugs into your old one.
Well Mat , Andy, oh my GOD what a difference. Was able to Data log first. Can't wait to compare. Thanks guys Now I know what the 383 should feel like. Balls to the Walls |
Posted on: 2013/10/14 4:28
