228 user(s) are online (173 user(s) are browsing Forums)
bigmoe "sys" flashing in info centre
Manitoba
118 Posts
My 94 didn't get much time on the road this season. The other day I was driving it to the storage unit and "sys" was flashing occasionally to the left of the fuel gauge. I remember when I started the car thinking the battery was a bit weak but it fired up quickly and I didn't give it a second thought. While driving I scrolled through the gauges and the volts were reading okay. Of course my manual is in the car in storage so I can't look it up. So what does sys indicate?
Posted on: 2013/11/3 0:02
bogus Re: "sys" flashing in info centre
SYS indicates an issue with the CCM... Central Control Module. It has an issue of some sort.
In your case, I would agree, low battery. Always store with a battery tender, or else this can happen. Most ppl don't realize that the alternator is not designed to recharge a weak battery. It's designed to top off a battery that just started the car, then run the car.
Posted on: 2013/11/3 0:08
Matatk Re: "sys" flashing in info centre
Yup, battery issue. Even if the voltage looks ok, the battery may have a short or bad cell internally.
Posted on: 2013/11/3 2:05
