227 user(s) are online (176 user(s) are browsing Forums)
Ultraman, more...
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
matts85vet probe moleculite pistons
Toledo, Ohio
58 Posts
i'm considering these for my 383 build:
http://www.probeindustries.com/Chevy_ ... p_SRS_Pistons_p/14106.htm
they are lightweight at 343g. anyone use them?
Posted on: 2013/12/4 3:20
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
rklessdriver Re: probe moleculite pistons
There is nothing wrong with them per say... they are actually very nice.
They won't stand any nitrous and are HP limited normally aspirated to about 450 because of the thin deck.
The 1.2, 1.5, 3mm ring package is great for maximizing hp in limited induction type engines but they are fairly expensive.
Posted on: 2013/12/5 2:24
