269 user(s) are online (200 user(s) are browsing Forums)
Also known as NHMS....
1989Convertible blower will not shut off
Buna Texas
69 Posts
Has my relay gone bad? When I turn off the car the blower stayed on last night, I have a kill switch on the battery so I was able to turn it off with that.
Posted on: 2014/2/12 1:06
Matatk Re: blower will not shut off
99% chance it is the blower control module went bad, located on the passenger side firewall on top of the blower box with two wire plugs coming out. Get ready for sticker shock.
Posted on: 2014/2/12 1:30
1989Convertible Re: blower will not shut off
Buna Texas
69 Posts
Yeah, what kind of sticker shock?
Posted on: 2014/2/12 1:36
If you want a new one about $110, you can find them used on eBay in the $40 range, if you have a pick and pull you might find one from $10-20.
Posted on: 2014/2/12 1:37
Look at post #33 here for interchange parts cars and numbers.
Posted on: 2014/2/12 1:43
Buna Texas
69 Posts
Found a new one for 90 bucks.
Posted on: 2014/2/13 0:38
Pcolt94 Re: blower will not shut off
Orlando
31 Posts
If the ground opens up on the blower module, the blower can run. Check for any burnt or broken wires or connectors not making contact on the module.
Posted on: 2014/3/29 2:18
