jonszr1 | which fuel pump is the primary on a zr1 | ||
paul Harvey on my black cr got her running and she just purred got to the front gate and she hit 178 deg and poof she stopped . on a zr1 both pumps run till 178 then the secondary kicks off. so I bought a new pump but don't remember which one of the 2 is the primary .??????
Posted on: 2014/11/18 4:00
bogus | Re: which fuel pump is the primary on a zr1 | ||
there are also 2 fuel pump relays... on the passenger side, 3rd relay from the trans tunnel... and on the drivers side, 1st relay next to the trans tunnel... Check them both.
If I am reading the manual correctly, the secondary pump will have a light green wire leading to it. The primary has a grey wire. There is also a code for all of this... H54 or H55. |
Posted on: 2014/11/18 6:36
-=Jeff=- | Re: which fuel pump is the primary on a zr1 | ||
my suggestion replace them both.. I think I am on borrowed time on mine..
Need to buy some replacements |
Posted on: 2014/11/19 13:30
jonszr1 | Re: which fuel pump is the primary on a zr1 | ||
trouble is I m cash poor right now lost my job and am trying to pay cash for a place to live . ssi will kick in in april but till then I am selling pencils . the place I am buying is only 32500. but it is on 3/4 of an acre with a 2 car garage go to. homes.com ridgecrest ca 4056 sydnor . set the scan for low to high . it is a little grey place that was listed for 35k . a fixer upper .t least I wount have to pay rent. as ssi will only be 1300 a month
Posted on: 2014/11/19 18:37
Donno if this helps, but... www.rockauto.com has the pumps you need at a fair price.
The Airtex brand, for $39 each, less the 5% discount code (D0499A8E6B7458). That's a chunk off the street price of $73.00. You will need strainers, tho. Carter STS1 strainers are $4.11 each. So... an estimate... with shipping to 93555 (Ridgecrest, CA), and the discount, the final total is $96.43. Which is not much more than the price of one pump and strainer at O'Riely's... Their total is $90.00 ($73 for the pump, $9.99 for the strainer, plus sales tax, 9%(?), that's about $90!)... Damn, that's a killer difference... nearly 2 for 1!!! For the EXACT SAME PART. |
Posted on: 2014/11/22 22:43
wow thanx rock auto is the place to go .
Posted on: 2014/11/22 23:14
