287 user(s) are online (198 user(s) are browsing Forums)
teebee, more...
Frank Right Head light
188 Posts
Here's a new one. My right front head light needs a lot of help opening and closing. I had a look at the head light "gear box" and decided I needed to call on you guy's. Is there a part within that is a common fail or does this thing need an overhaul. I appreciate any and all suggestions. 1984.
Posted on: 2015/8/4 21:37
bogus Re: Right Head light
it is basically an overhaul...
there are a couple of gears and these little bushings, which, over time, wear out.
the parts are about $20 for both, the labour is another 90 min each.
Posted on: 2015/8/4 23:05
Frank Re: Right Head light
188 Posts
Rock Auto?
Posted on: 2015/8/6 21:45
Matatk Re: Right Head light
What Andy said.
84-87 didn't have the bushings. By the kit at any of the corvette websites or ebay.
Here are some pictures:
http://www.corvetteforum.com/forums/c ... ght-gear-replacement.html
Posted on: 2015/8/7 0:16
188 Posts
Wow, that's an excellent write up! Thanks.
Posted on: 2015/8/7 0:45
