Horsepower844182 | Gas Gauge reading changes? | ||
Well...say I put gas in my car and the little bars are up to the half way mark. Now if I start driving a bit, they might go down a bar or two, then if I coast for a while, they'll go up a few bars.
Is my reading suppose to change to match my driving habits? But the gas level in the tank doesn't change, so why does the readout? Shouldn't it be steady? |
Posted on: 2008/2/18 21:11
~Austin~ \´97 Firebird A4 15.86 @ 86 Stock w/ cutout \´92 Corvette A4 Bored and Stroked 383 LT1 Cammed 468rwhp |
MK 82 | RE:Gas Gauge reading changes? | ||
The sending unit for you gas gauge is a very hitech device. :tongue:
It consists of a float on a metal arm attached to a variable resistor. Your reading depends on the resistance at the time. They rust, get gunked by some fuels, and become erratic. Unfortunately, to replace it, you cant buy just the resistor. You must buy the whole tank spout and associated bits minus the fuel pump and strainer. The replacement is ridiculously expensive. There is a procedure for cleaning the variable resistor that sometimes works. http://forums.corvetteforum.com/showthread.php?t=1574491 |
Posted on: 2008/2/18 21:38
96 CE Roadster LT4 |
Horsepower844182 | RE:Gas Gauge reading changes? | ||
That's a really good post. I was hoping it was just the way it was. Looks like I have a little project this weekend
Posted on: 2008/2/18 22:17
