224 user(s) are online (165 user(s) are browsing Forums)
Slalom4me Head Location: Offset Dowel Pins
Edmonton, AB
165 Posts
Are offset dowel pins available for locating heads on SBCs?
If so, a link or name will be appreciated.
Alternatively what remedial action is suggested for a block with a dowel
pin that appears to be slightly miss-located on one bank. I would like
to find some middle ground between using a large persuader and custom
offset machining a single dowel or drilling and bushing.
Posted on: 2008/3/1 7:13
CFI-EFI RE:Head Location: Offset Dowel Pins
Top of Utah
372 Posts
Summit has them. These are offset by [color=blue:8693b3f7fa].015"[/color:8693b3f7fa], and these are offset by [color=blue:8693b3f7fa].030"[/color:8693b3f7fa].
RACE ON!!!
Posted on: 2008/3/1 23:51
Slalom4me RE:Head Location: Offset Dowel Pins
Edmonton, AB
165 Posts
Thank you CFI-EFI. I did not know these were available
commercially and they ought to be an ideal solution for
the misalignment issue.
Moroso Offset Cylinder Head Dowels
"Improve your intake flow.
These offset cylinder head dowels from Moroso reposition
the cylinder heads upwards on the block toward the lifter
valley. This moves the valves away from the cylinder wall
for improved intake flow."
OD (in): 0.316 in.
Hgt(in): 0.629 in.
#37920 - 0.015" Offset
#37930 - 0.030"
Posted on: 2008/3/3 16:10
