119 user(s) are online (65 user(s) are browsing Forums)
chisgt 88 vert, what distributor should i run?
chitown
58 Posts
Hey guy's I bought a MSD#8366 to put in my ZZ383 motor with the first fuel injection unit. The shop that is helping me install called today to tell me that the distributor will not work with the existing wiring harness. What are people using and do you have any suggestions? Also the motor calls for a distributor with a melonized gear. Hoe do I tell if mine is a melonized gear? Thanks tim
Posted on: 2008/3/7 3:49
Raidmagic Re: 88 vert, what distributor should i run?
Florida
168 Posts
They 8366 is a small cap dist. meaning you need an external coil. You can get the wiring to go from your factory wiring from Jim's performance and then it will be a plug and play deal.
Posted on: 2008/3/8 15:17
