LD85 | Push Type Clutch / ZF install interest? | ||
Saturday I will put my ZF back in, install the Howe push TOB, an extended Pilot Busing, add a 1/4" mid engine plate for spacing,
Any interest in pics and a write up? |
Posted on: 2008/6/4 0:04
2005/Z51 |
FATED | Re: Push Type Clutch / ZF install interest? | ||
I would be interested in some Pics. This pull clutch thing isn't working out. The nylon sleeve was missing from the TOB and no one has the 94-95 TOB. Looks like plan B.
Posted on: 2008/6/4 0:09
1985, Performance Chip, hole in muffler, and other Mods |
CentralCoaster | Re: Push Type Clutch / ZF install interest? | ||
Only place that has the TOB by itself is AC-Delco. Rockauto.com is probably the cheapest source. The early tob has no nylon sleeve.
Fated, your cheapest way out from where you are now is to stick with the parts list. I'm not even clear on what parts you have now. But it sounds like a ZR1 clutch set for ~$250 is your missing link. |
Posted on: 2008/6/4 5:24
LD, I thought you had your setup working with the clutch pedal stop? Or are you trying a different setup?
Posted on: 2008/6/4 5:27
LD85 | Re: Push Type Clutch / ZF install interest? | ||
It's working, but I never really took pics, posted measurements and a "how to" all in one thread,I'll put the tranny back in Friay evening or Saturday monring. I want ot head over to the Good Guys Nationals car show on Sundy at ORP. |
Posted on: 2008/6/4 7:11
2005/Z51 |
Checked everywhere for TOB and all were not carried or out of stock. Bought a clutch set. The TOB I have has a bore oof .370 so it is too small for the early and hangs on the pilot sleeve with about 3/32 yo spare so I assume the bushing is gone. I was wondering how long it took them to get the packing material out when the installed the damn thing. |
Posted on: 2008/6/4 15:16
What do you mean by pilot sleeve?
The black tag (89-mid94) TOB is ACDELCO Part # CT1073, GM#10203567 I can't seem to find the blue tag one (mid94-96). BUT, I think I have a brand new one at home I was keeping as a spare, with the nylon sleeve in it, if you've got a blue tag trans. Would you be interested in it? |
Posted on: 2008/6/4 21:18
I sure would. PM me with details.
By pilot sleeve I mean the tube that comes out of the front bearing retainer and the TOB slides back and forth on it. I have about 3/32 inch slop here and I belive it is because that nylon sleeve is missing. |
Posted on: 2008/6/4 23:18
-=Jeff=- | Re: Push Type Clutch / ZF install interest? | ||
Larry,
Yes pictures would be AWESOME!! |
Posted on: 2008/6/5 3:09
Randyj75 | Re: Push Type Clutch / ZF install interest? | ||
Larry, I love to see some pictures.
Posted on: 2008/6/6 4:46
'90 Corvette, M6,a few mods, more to come |
