mojo92 | Motor running rich | ||
We just got the motor back in the car after a rebuild and now the motor is running rich. We think that one of the injectors is bad. We took it lose and the tune did not change like it did with the others. #1 injector I thank, would this make the motor run that way ?
Posted on: 2008/8/3 23:29
FATED | Re: Motor running lean | ||
Yes, might run hot too.
Posted on: 2008/8/3 23:34
1985, Performance Chip, hole in muffler, and other Mods |
bogus | Re: Motor running lean | ||
check the fuel filter.
check fuel pressure. Be sure the fuel pressure regulator is doing its job. be sure there aren't any vacuum leaks. |
Posted on: 2008/8/3 23:43
mojo92 | Re: Motor running lean | ||
would it be a good thing to buy a all new injector, fuel rail and fuel pressure system ?
Posted on: 2008/8/3 23:48
injector. It is SO rare when the rail fails...
FPR is a good idea, especially if the new engine is more than stock. Specs, please? |
Posted on: 2008/8/4 0:08
MK 82 | Re: Motor running lean | ||
Running rich doesn't make it run hot. Actually the opposite. |
Posted on: 2008/8/6 2:30
96 CE Roadster LT4 |
Posted on: 2008/8/6 2:31
