biggrizzly | To EGR or not to EGR? | ||
Well I got the headers on finally, but now my quandary is whether or not to use the EGR. The headers have fittings for EGR but I haven't drilled them out yet.
I was trial fitting the EGR tubes and I can already tell they are going to be a PITA to fit properly without a bunch of bending, cutting and welding back together. What did you guys do to get your EGR tubes on the LT-1 to fit? Did you bend them or cut and re-weld them? To delete the EGR system on an LT-1 what all comes off? Will it kill my chances at a clean emissions test? |
Posted on: 2008/8/13 3:16
bogus | Re: To EGR or not to EGR? | ||
If you have smog tests, keep it for sure.
I like EGR, it helps keep detonation down and reduces NOx, which is a really REALLY bad pollutant. |
Posted on: 2008/8/13 3:50
MK 82 | Re: To EGR or not to EGR? | ||
Are you talking about the air injection tubes?
Posted on: 2008/8/13 16:16
96 CE Roadster LT4 |
biggrizzly | Re: To EGR or not to EGR? | ||
yes |
Posted on: 2008/8/13 17:45
BrianCunningham | Re: To EGR or not to EGR? | ||
The air injection and the EGR are not the same thing.
BTW during WOT all of that's turned OFF anyways, so you really don't gain anything. |
Posted on: 2008/8/13 18:35
