Slalom4me | [Datalogging]C6/C6Z ODB Interface for Racepak G2X, G2XPro & IQ3 Loggers | ||
C6 owners interested in datalogging vehicle parameters
may want to look into an interface that enables data from OEM sensors to be logged along with GPS position, accelerometer loads and input from any external sensors that a user has. The interface consists of a cable that plugs into the scan port of the vehicle and runs to the datalogger. Hook-up is plug-and-play. Here are the parameters that are drawn from OEM sensors by the interface. 1. Engine RPM 2. Throttle Position 3. Throttle Pedal Position 4. Oil Temperature 5. Water Temperature 6. Transmission Temperature 7. Intake Temperature 8. Battery Volts 9. Wheel RPM (all four wheels) 10. Yaw 11. Torque 12. Horsepower 13. Brake Pedal Position 14. Gear Position Vehicles like my C4 with ECM/PCM that DON'T support this ODB interface require require hardware to be purchased and mounted to log inputs beyond the system defaults. Even finding a suitable source for the default RPM capability is sometimes a challenge and may require a third-party signal conditioner. Other external inputs can cost $200+ per channel. However, for less than the price of three external sensors (and none of the installation drama), folks with the C6 platform can just plug in the new interface and receive 14 channels. Of these, the wheel RPM & Yaw inputs are particulary remarkable because they present more challenge and cost to implement through external sensors. Here is a link to a document from RacePak. It mentions a contact person for further details (pr aht racepak.com.) The go-to guy for my G2X questions in the past has been Tim Anderson (tim aht racepak.com.) . |
Posted on: 2008/10/2 18:23
ghoffman | Re: [Datalogging]C6/C6Z ODB Interface for Racepak G2X, G2XPro & IQ3 Loggers | ||
I saw this at PRI, and I was extremely impressed. I think I will end up getting this with the G2X pro. I spoke to Tim Anderson (423.968.5429, tim aht racepak.com.) and it looks like the G2X Pro is better for me since I do so much shock and spring development, I can add the shock displacement transducers and ride height sensors. For most guys the cheaper G2X is the way to go, and it has a very cool small dash to go with it as well.
Posted on: 2008/12/21 14:35
