182 user(s) are online (116 user(s) are browsing Forums)
cor123, more...
81c3 Installed a New Clutch in my Z06
Colorado
143 Posts
Took my 20 hours total, with headers,air tools and on jack stands going along cautiously. Its kind of a PIA, but not extremely terrible. If anyone is thinking of doing this job, lemme know if I can give any pointers.
Posted on: 2009/4/30 2:01
CSS996 Re: Installed a New Clutch in my Z06
Mega Guru
Central PA
3644 Posts
Notice any difference?
I remember you mentioning a little bog on the 3-4 upshift. But I read that while the lower gears had different ratios than the standard coupe, the Z06 used the same 4th gear. (5&6 too, I would assume)
Feel free to call me if you ever need a tool runner while you're doing that stuff. I'd love to learn from the master!
Posted on: 2009/4/30 2:13
Currently "Between Vettes".
Jeffvette Re: Installed a New Clutch in my Z06
4th is the same 1:1, but the M12 box had a different 5th and 6th gear as well.
Swapping out the clutch on the C5/C6 is a crappy job. Just a lot of work to remove all the pieces to get at it.
Hope you installed a remote bleeder John.
Posted on: 2009/4/30 2:29
Mega Guru
Central PA
3644 Posts
Thanks for setting me straight.
Posted on: 2009/4/30 2:54
81c3 Re: Installed a New Clutch in my Z06
Colorado
143 Posts
Absolutely! Also did the rear axle seals and torque tube bushings too! It was also a good opportunity to clean everything up under there.
Chris, youre always welcome to come over. Just call me!!
Posted on: 2009/4/30 4:48
bogus Re: Installed a New Clutch in my Z06
damn... sounds like a task and a half.
I need to do this on my 92... been there, done that.
Posted on: 2009/4/30 5:45
How did you like that big "C-clip" in the torque tube?
Posted on: 2009/4/30 6:07
Colorado
143 Posts
Jeffvette wrote:
[How did you like that big "C-clip" in the torque tube?
Well, I have a bad habit of cursing, but while trying to get that POS outta there I think I made up some new ones!! I used a huge pair of channel locks on the back of my snap ring pliers to get enough squeeze on them while my wife fit a screwdriver behind the snap ring. In short, it sucked big time!
Posted on: 2009/4/30 18:57
Steve40th Re: Installed a New Clutch in my Z06
1114 Posts
Sorry to bring back an older thread. Going to be doing a 03 ZO6 clutch on Saturday, and tips and tricks (pics too) would be great.
I will be using a lift, air tools etc. Putting an LS-7 clutch, flywheel, pressure plate etc etc.
Posted on: 2011/5/31 16:18
Ko'u ohana aia ku'a ikaika
1114 Posts
Remote Bleeder? Place to buy?
Posted on: 2011/5/31 16:19
http://www.vetteweb.com/tech/vemp_061 ... lutch_flywheel/index.html
Posted on: 2011/5/31 17:02
1114 Posts
Boy this is going to be no fun whatsoever. The kid we are helping bought this car, and its his first stick shift, first corvette, and drove it with the clutch to the floor for some time. We should start charging people for assisting them here in Oahu.
Posted on: 2011/5/31 17:08
I would.
The best way to cure stupid is charge them for it.
Posted on: 2011/5/31 19:49
1114 Posts
I would.
Thats true.
Posted on: 2011/5/31 20:01
And take him along... have him learn and understand the effort.
Posted on: 2011/5/31 20:26
1114 Posts
He did ask to be involved in the whole process. Little Jedi will be, trust me.
Posted on: 2011/5/31 20:40
