EricVonHa | 401cid Preliminary Dyno Results | ||
The quick and dirty? There's more in it. Past 5800rpm the A/F ratio quickly shot up to almost 14:1 so we didn't push it any further. Up to 5800 it's still building strong linear power and with more fuel-- it should be good for a couple more hundred rpm.
Base fuel pressure is set to 44psi (no vac) Timing is low 30's (no knock retard, yet!) This was with a 58mm throttle body. My Arizona Speed and Marine monoblade is still awaiting repair. |
Posted on: 2009/8/28 19:37
BrianCunningham | Re: 401cid Preliminary Dyno Results | ||
pretty flat torque curve
what cam are you running? |
Posted on: 2009/8/28 20:07
EricVonHa | Re: 401cid Preliminary Dyno Results | ||
This is the ZZ-X TPIS cam. .560"
Posted on: 2009/8/28 20:53
88BlackZ51 | Re: 401cid Preliminary Dyno Results | ||
What is the duration and lobe seperation? I can't seem to download your link. Can you post it another way, or scan it possible? |
Posted on: 2009/8/28 23:19
Nevermind. The link worked.
Posted on: 2009/8/28 23:22
