LesPutnam | >88 headlight motor bushings. | ||
The headlight drive motor bushings are available at your local parts store for just a couple of bucks. These are of the original material which are designed to slightly cushion the drive system when it reaches the stops. I have always felt the delrin aftermarket replacements subjected the drive to too much shock.
Apparently the bushings were originally used in window drive motors on Fords up to 2003. Look for a parts store that handles the "HELP!" line of aftermarket parts. The part number is 74410 (Window Regulator Gear Plugs) for a package of three. Les |
Posted on: 2009/9/10 15:31
rayquayle | Re: >88 headlight motor bushings. | ||
Great tip, Les. Thanks for sharing.
Posted on: 2009/9/10 17:48
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
Matatk | Re: >88 headlight motor bushings. | ||
I've never heard that the HELP line had them. Very good to know!
Matthew |
Posted on: 2009/9/10 20:24
LesPutnam | Re: >88 headlight motor bushings. | ||
While picking up some stuff at Advance Auto for my upcoming intake re-seal / injector swap I double checked and realized they are more than a couple of bucks. Oops. Eight something was more like it, but there they were on a hook non-the-less.
Posted on: 2009/9/14 0:47
pappyfreebird | Re: >88 headlight motor bushings. | ||
well its 15 fum ecklers fer 6 to the door ,,so great info n saves the wait..althou fluffs way of 12mm-1/2' hard plastic rod is cool too..real cheap if handy
Posted on: 2009/9/14 1:13
