151 user(s) are online (91 user(s) are browsing Forums)
bogus Hard Starting Jeep
Our 1993 Cherokee (I-6) has always been a slow starter, but over the last couple of months or so, it's gotten worse.
And it would always require that you floor the pedal to start, with 5+ second crank times and a killer smell of raw fuel. Once started, the idle sucked. It would take another 20+ seconds to "wake up".
Well... I tested the injectors... the old cardboard test. #3 injector was dripping. Not at a huge rate, but enough to tell me that one injector was bad and the others suspect.
I replaced the 6 with a new set of Ford Motorsports Orange Tops - 19#.
Results?
Start time is now 2 seconds or so. There is no longer the need to floor the throttle, either! The idle is smooth and steady, right after start up.
Total success.
Posted on: 2009/1/23 4:42
wesmigletz Re: Hard Starting Jeep
Land of Fruits and Nuts
325 Posts
Bogus, congrats on the fix. It's nice to read about something going right for you...
Posted on: 2009/1/23 5:17
bogus Re: Hard Starting Jeep
yea, a win right now feels real sweet!
Posted on: 2009/1/23 5:34
Matatk Re: Hard Starting Jeep
22810 Posts
Glad you got it fixed. I never had that problem with my 93 cherokee, but I got rid of it about 7 years ago.
Posted on: 2009/1/24 2:39
pianoguy Re: Hard Starting Jeep
Excellent!
Posted on: 2009/1/24 4:52
It's been a couple of weeks now, and it's simply running like a brand new Jeep! Fantastic.
Posted on: 2009/2/7 23:25
BrianCunningham Re: Hard Starting Jeep
you were do for a break
Posted on: 2009/2/7 23:39
