MikeG | Best way to store tires | ||
A friend put 18S on his 96 and gave me a set of Goodyear Eagles GS-Cs with 400 miles on them. Right now my pilot sports are ok for a few thousand more miles. Whats a good way to store these until next summer? Thanks !
Posted on: 2011/10/31 20:50
BillH | Re: Best way to store tires | ||
Best in a warm(er) place that doesn't freeze. It probably won't make much difference though, cars are parked outside all winter. I did some testing a few years ago on racing slicks. I bagged the tires (garbage bag with the air sucked out with a shopvac. The tires that were bagged came back to life faster on the track than the set that sat in the open. So, you could do that but I don't think it's a big deal on street tires. |
Posted on: 2011/10/31 20:56
TommyT-Bone | Re: Best way to store tires | ||
Damn Bill. I never thought of that (bagging) but it makes sense. If it's good enough for K rations and storing foods in the freezer should be good for rubber too.
Posted on: 2011/10/31 22:40
bogus | Re: Best way to store tires | ||
Yea, bagging is a good idea. Ground level ozone really kills a tire.
I would consider a good tire treatment first, on all outside surfaces, then suck it out and seal it tight. Stack in a basement or garage. Don't leave them outside. Shadier the better. Light will activate the ozone and kill whatever benefits you have had from storage. If anything, use a black plastic bag. www.tirerack.com should have some tips for winter storage, too. |
Posted on: 2011/11/1 0:26
flyboy | Re: Best way to store tires | ||
Nitto recommends reducing air pressure by half for long term storage with their drag radials.
Posted on: 2011/11/1 0:54
If storing with air, I would consider a nitrogen fill.
Posted on: 2011/11/1 1:36
All that will do is decrease the moisture level in the tires. And I dought it would be to a point where it would have any effect. |
Posted on: 2011/11/1 1:52
