235 user(s) are online (151 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
Corvette90 oil pumps, once more....
11 Posts
ok, one more oil pump thread...
so, is there any traditional wet sump oil pump around in the aftermarket, that..
.....is rated high performance
.....have a "good" heavy housing, that doesn´t crack
.....have billet gears, no p/m gears
i searched around, but didn´t come up.....
thank you
Posted on: 2008/1/5 11:55
Midnight85 RE:oil pumps, once more....
Streator, IL.
264 Posts
The Melling "M" Select pumps have what you are looking for, also on the "other" forum there is the well known Melling thread, if you go back a ways in it there are some other brands of pump that are NOT actually Melling. I want to say Milodon was one but I'm not sure.
The select pumps all have a five digit part number beginning with 10
Posted on: 2008/1/5 19:13
Corvette90 RE:oil pumps, once more....
11 Posts
hi, and thank you!!
ok, with the M-selects, i have the stronger casting....but no billet gears...
it seems, that most (all?? ) new pumps have p/m gears, that are not that tough than billet..they seem to break from time to time...
http://www.4m.net/archive/index.php?t-9657.html
http://speedtalk.com/forum/viewtopic...44a8b3c875d287
http://speedtalk.com/forum/viewtopic...69f83120f28c85
greetings...
Posted on: 2008/1/5 19:22
bogus RE:oil pumps, once more....
I have to ask these questions...
How many OEM SBC oil pumps fail? I sure don't hear about them.
How good does an oil pump gear HAVE to be? It's bathed in oil after all...
Posted on: 2008/1/5 19:34
Streator, IL.
264 Posts
I agree, you're being a bit too
sensitive about the gears. Besides
I'm thinking the "M" select pumps
do have billet gears. Before Melling
had a brain fart and lightened their
pumps I used to twist a 350 to
8000 rpm all the time when I was
drag racing. Never ever had a
problem.
Posted on: 2008/1/6 1:05
