684 user(s) are online (333 user(s) are browsing Forums)
Dale1990 Recommended replacement for leaking injectors
Conway, AR
128 Posts
In a different thread I found I have at least one leaking injector. Any suggestions for a replacement?
The engine is a Super-Rammed 383 with ported 113 heads and an LPE JL2 cam, I believe. Basically, a mild 383. The last time these injectors were send in for cleaning, they flowed 24.4-24.8lbs IIRC so I would guess some 24lb-ers would fit the bill.
Thanks!
Posted on: 2009/12/27 20:22
FICINJECTORS Re: Recommended replacement for leaking injectors
Gold Sponsor Vendor
117 Posts
Posted on: 2009/12/28 13:20
Dale1990 Re: Recommended replacement for leaking injectors
Conway, AR
128 Posts
Cool! I'll be ordering them soon. Thanks for the the help!
Posted on: 2009/12/28 13:37
86 Coupe: SR 383
90 Convertible: Stock L98
06 Z06: Stock LS7
Gold Sponsor Vendor
117 Posts
you're welcome
Posted on: 2009/12/30 1:43
