klkordzi | My Air Pump Eliminator bracket | ||
Here are a couple photos of my engine I recently changed the heads, cam, added headers and roller rockers to. I also made up an air pump eliminator bracket and actually used the bracket from the air pump itself. Lastly I made up lower brackets for my rear coilovers that allowed my to eliminate the shock mount and also space the coilover away from the knuckle enough to eliminate interference. I threw in a couple pics of the interior.
Posted on: 2010/1/24 16:03
Durango_Boy | Re: My Air Pump Eliminator bracket | ||
Sorry not seeing any pics, though very interested to see what you did.
Posted on: 2010/1/24 16:37
klkordzi | Re: My Air Pump Eliminator bracket | ||
Sorry, I'm having problems posting a picture. Can you tell me how to do this?
Posted on: 2010/1/24 17:02
CentralCoaster | Re: My Air Pump Eliminator bracket | ||
They show up for me.
Where did you get the sway bar links, or did you make them? How are they holding up? It seems like they might twist with that setup if those are the stock bushings. |
Posted on: 2010/1/25 6:59
The end links I made up.
Posted on: 2010/1/26 0:54
