apeacefulstorm | Warm or hot air only..... | ||
I think I read somewhere that warm air or hot air coming out of the vents when the a/c is turned on could mean that that electronic door motor has failed and is shut, allowing only the hot air to blow through... is that correct?
Posted on: 2010/4/3 0:22
"I have the need, the need for speed...." |
Matatk | Re: warm or hot air only..... | ||
That's one possibility. You could also have a bad head unit. Or be low on freon. Sorry to say it's time to do some diagnostics.
Matthew |
Posted on: 2010/4/3 1:21
apeacefulstorm | Re: warm or hot air only..... | ||
ahhhh now that you mention it, the head unit has been acting weird... the outside temperature display does not display the correct temp, and when I first turn on the car the light flashes for a minute or so before remaining solid... will definitely pass that info on to the mechanic.... |
Posted on: 2010/4/3 4:12
There is a way to do self diagnostics on the system. I'll have to dig up the info later.
Matthew |
Posted on: 2010/4/3 11:27
