151 user(s) are online (100 user(s) are browsing Forums)
Fluff Rear lights on a C4
Winchester UK & Alicante ES
247 Posts
Can anyone tell me about the standard US spec for the rear lights on a 93 C4. Does each of the 4 red lights have a combination of rear/stop/turn bulbs as standard?
Mines been converted to euro spec and I want to do some changes, but I'm not sure what wiring/configuration was originally there.
Posted on: 2010/6/3 22:46
93 LT1 Coupe.
bogus Re: Rear lights on a C4
20861 Posts
originally, the C4 rear lights are both red, both turn, both marker and both brake.
Easy.
Moving to C4 Tech.
Posted on: 2010/6/4 5:01
vis_croceus Re: Rear lights on a C4
VA
260 Posts
Each lamp has one dual-filament bulb, type 2057.
Posted on: 2010/6/5 4:44
94 vert
Fluff Re: Rear lights on a C4
247 Posts
Thanks Andy & vis,
That sounds good. Depending on what was done during the euro conversion I should be able to do a mod to accept 4 amber & red combination units.
Where do I find the flasher unit/relay on a 93?
Posted on: 2010/6/6 10:12
93 LT1 Coupe.
20861 Posts
The flasher is under the driver side knee bolster, IIRC... just about every relay is under the right side knee bolster.
Posted on: 2010/6/6 22:28
247 Posts
Thanks Andy.
Posted on: 2010/6/7 11:22
93 LT1 Coupe.
