145 user(s) are online (86 user(s) are browsing Forums)
Corvette90 oil pressure relief spring
11 Posts
hi
i received my M-10552 pump today, and it have the pink high pressure spring installed...
currently i run a SV/SP "non-performance"pump.., its a Sealed Power (that is made by Melling)
can i just swap the springs? are they equal length?
thank you
Posted on: 2008/1/14 17:17
CFI-EFI Re: oil pressure relief spring
Top of Utah
372 Posts
I'm not familiar with the differences in the new and old Melling pumps. I would think the springs should be interchangeable between early and late pumps. The stiffer relief spring won't have any affect on the oil pressure until it reaches the relief pressure of the weaker spring. Is that likely?
RACE ON!!!
Posted on: 2008/1/15 0:38
