Steve40th | Split BLMS, Can you look at log and see anything? | ||
I will try to upload a TTS datalog for my 93. My BLMs are split pretty bad. WHat changed, just the injectors. I changed the constant, and that was it.
Posted on: 2010/7/21 3:22
Ko'u ohana aia ku'a ikaika |
Aboatguy | Re: Split BLMS, Can you look at log and see anything? | ||
Steve,
I tried to play the file but for some reason it doesn't look right on my netbook. Mike |
Posted on: 2010/7/26 15:35
Steve40th | Re: Split BLMS, Can you look at log and see anything? | ||
I think its because you need the actual TTS file for my DA2 build. |
Posted on: 2010/7/26 15:41
vis_croceus | Re: Split BLMS, Can you look at log and see anything? | ||
Save as CSV? |
Posted on: 2010/7/26 22:30
94 vert |
Unless you know something I dont, can you change a uni to a file CSV? |
Posted on: 2010/7/26 22:45
Datamaster exports to csv. |
Posted on: 2010/7/27 4:55
94 vert |
How do I do it? I need to read up on this. Here it is, pretty cool. |
Posted on: 2010/7/27 4:59
