248 user(s) are online (194 user(s) are browsing Forums)
klkordzi Input on Targa brace
Pittsburgh, Penna
152 Posts
I've been thinking of making up a targa brace as it doesn't seem that complicated to make up. I had been thinking of two versions. One made up up of rectangular tubing to keep it as low profile as possible. The other uses heim joints and swedged rods. The heim joint version would allow me to put some tension into play but I question whether that is advisable. I also don't think it would provide the rigidity that a solid brace would. All input and ideas are welcome!
Posted on: 2010/8/19 0:19
Steve40th Re: Input on Targa brace
1114 Posts
Go solid as it keeps integrity of original design. I have a RD Racing Targa truss. Not pretty, but it works well.
Posted on: 2010/8/19 18:29
Ko'u ohana aia ku'a ikaika
383tpimachine Re: Input on Targa brace
Corpus Christi
976 Posts
im building one as well out of solid aluminum. I miss the sunburn I get with the top off but hate the flex
Posted on: 2010/8/19 20:03
1970 El Camino-Awaiting LSX
klkordzi Re: Input on Targa brace
Pittsburgh, Penna
152 Posts
I was thinking of using rectangular tubing in the 1 x 2 range to keep things flatter than the R&D brace. Also want to miter the center piece to the front and back which is also different than the R&D one.
Posted on: 2010/8/20 13:33
Corpus Christi
976 Posts
When I have all my dimensions figured out im going to have it cut with a water blade. My design is out there but should work very well
Posted on: 2010/8/20 13:47
Pittsburgh, Penna
152 Posts
What kind of cost are you looking at?
Posted on: 2010/8/21 3:25
Corpus Christi
976 Posts
I have the hookup for the aluminum sheet. I just have to draw the design and have another friend cut it out.
sheet of metal is 4x3 and 1/4in thick IIRC
Posted on: 2010/8/21 12:40
ggrassmid Re: Input on Targa brace
Edgewood, KY
18 Posts
check this out.. http://www.prostreetcustoms.net/index.html
I bought one, made a huge difference. Tom Gasper is a good guy to work with. The front mounting points needed to be machined out some more to fit my 85 car, and we had no problems working that out. I far prefer to drive with the bar on now than with my arylic top!
Posted on: 2010/8/23 15:53
